Results 1 to 6 of 6
Thread: Revit to 3dsMaxDesign Workflow
    July 9, 2013
    2
    01:37 AM
    Hey,
    I am currently using Revit 2013 and 3dsMaxDesign 2013. I having linking problems as I am unable to reload the revit file as I am using different desktop and the path is different on each desktop.
    Is there any way to solve this problem without the need of adding material again?
    Thanks for your time
    April 5, 2013
    38
    09:37 AM
    Why don't you link it to a network drive that they all load off of?
    July 9, 2013
    2
    01:37 AM
    Quote Originally Posted by veuxx View Post
    thanks for the tip, however I have no administrative rights to go into it as I am using my school desktops.
    Coeur d Alene, ID
    4,698
    09:37 AM
    Quote Originally Posted by duckiemama View Post
    The need for a network (server) location would benefit schools so much more...everything is kept in the same place....instead of having to save to a USB then to a workstation then save to the USB at the end of class...
    April 5, 2013
    38
    09:37 AM
    My university had a pretty decent computer lab with a network for the students/faculty to use.
    Moderator gaby424's Avatar
    December 11, 2010
    911
    06:37 PM
    I had the same problem.
    Anyway this doesn't help you without admin rights.
    I didn't want to depend on a server (I like to be mobile same time). So every computer has a D partition these days. I made a d:\\render\projectX\maps\ folder for every rendered project.
    I installed a software that automatically sincronize bidirectional those folders in the same second I add delete something. The Revit FBX files are there too. The software works in background exactly like Dropbox. The only difference is that it is instant/offline/and only hardisk constrained in terms of space.
    I use resource collector tool in 3d max to redirect all the paths of the scene materials to that folder, ones I know I had to change the PC. My maps main library is only on one PC. But with the process described above I only duplicate the "in use" scene maps.
  1. Cloud render compared to 3dsMaxDesign 2013 render (internal)
    By willsud in forum Rendering and Gallery
    Last Post: September 6th, 2013, 09:27 AM
  2. Revit workflow
    By amolese in forum Architecture and General Revit Questions
    Last Post: August 18th, 2012, 02:11 PM
  3. SKETCHUP to revit workflow?
    By TDHArchitecture in forum Architecture - Family Creation
    Last Post: April 26th, 2012, 02:22 AM
  4. Revit Detailing Workflow
    By madeforworship in forum Architecture and General Revit Questions
    Last Post: August 17th, 2011, 01:58 PM
  5. Klaus Cornell Box in 3DSMaxDesign 2012
    By rpict in forum Rendering and Gallery
    Last Post: June 30th, 2011, 12:08 AM
