Results 1 to 6 of 6
Thread: how do you get light fixtures to glow?
    March 29, 2012
    10
    09:12 AM
    Yes there is probably a very easy answer to this but I cant find anything regarding making the light fixture, for example a recessed can light, to "glow" in a rendering. sorry for the dumb question but if anyone could help that would be greatly appreciated. I am currently only using the light fixtures that come with revit in my renderings. thanks. thomas
    Senior Member
    August 19, 2011
    New Hampshire
    503
    09:12 AM
    You will want to make sure that the light fixture uses a self-illuminating material on the inside of the housing.
    For reference, you can check out the Delray light fixtures we have over at ARCAT. Snag (transfer project standards) or look at the material used for the Reflector Finish parameter on the downlights and change it to suit your needs. You'll want to adjust the filter color of the self-illumination to match the color output of the lamp (light bulb) you are using.
    March 29, 2012
    10
    09:12 AM
    thanks so much Andrew. Sounds easy enough. So basically your saying light fixtures out of the box must be modified In order to "glow".
    December 21, 2010
    Phoenix, AZ
    2,556
    06:12 AM
    Or you can, if using an area light, turn on Emit from Shape (or whatever it says). Pretty sure you need to be at least at a Medium quality setting to see the effect.
    Senior Member
    August 19, 2011
    New Hampshire
    503
    09:12 AM
    Right. The downlights that come with Revit don't have the ability to glow without making modifications. You can use the paint tool to paint the inside of the housing the illuminating color, leaving the rest of the extrusion to function as the "trim" color.
    Senior Member rkitect's Avatar
    April 21, 2011
    Oklahoma
    773
    08:12 AM
    I have a couple of posts on how to achieve this over on my site:
    Search results for "material illumination"
    Let me know if you have any questions and best of luck!
  1. Ceiling-based light fixtures and elevations
    By hclbaumbach in forum Architecture and General Revit Questions
    Last Post: November 14th, 2012, 10:36 PM
  2. Light Fixtures Using IES Files
    By ELaforge in forum MEP - Family Creation
    Last Post: May 4th, 2011, 08:21 PM
