Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree6Likes
Thread: Advice on improving this 3D Presentation
    January 17, 2011
    1,982
    12:00 PM
    Hello all! Attached is a 3D perspective render view of a current project we are working on. I would love to have C&C's on how to improve the presentation. This is a simple Photoshop ensemble of fusing a Wireframe and Rendered View together and I really like how it turned out. Anyways, thanks in advance to all who contribute!
    Attached Thumbnails Attached Thumbnails Advice on improving this 3D Presentation-01.jpg
    Alex Cunningham likes this.
    Coeur d Alene, ID
    4,698
    10:00 AM
    Could use some more light on the rendered side
    December 21, 2010
    C.LONDON
    4,353
    06:00 PM
    I like the look you're going for - but I'd like to see more use of masking to differentiate between the elements that need to be rendered, and those elements that would look good in wireframe - i.e. "hidden" objects as wireframe, clearly-in-view objects, rendered (specifcally, the first items left most of the shot) - it's fairly easy to set your masks up in Revit with solid black surface pattern overrides (then export that image out, same size, to PS).
    Other than that, your lineweights could do with some tweaking - they're all a little chunky - and potentially some might look better reversed to be white.
    January 17, 2011
    1,982
    12:00 PM
    I did change the lineweights. I globally changed everything to a 1 lineweight and I like those results much much better.
    January 17, 2011
    1,982
    12:00 PM
    Here are the final outputs. I didn't have time to monkey with the brightness but maybe at a later time. I do agree it needs it a bit more. And obviously these aren't "renders" but a Rendered Visual Style is all.
    Attached Thumbnails Attached Thumbnails Advice on improving this 3D Presentation-01.jpg   Advice on improving this 3D Presentation-02.jpg   Advice on improving this 3D Presentation-03.jpg
    cellophane and Drew like this.
    December 21, 2010
    C.LONDON
    4,353
    06:00 PM
    I certainly like the third one best because the (or at least brightness of the) white surround "lifts" the image - the others feel, as Micheal noted earlier, a little gloomy still.
    March 7, 2013
    8
    09:00 AM
    Very nice work! Cool approach.
    Steven
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    844
    03:00 AM
    I like it, is it the world's biggest slushie machine?
    December 21, 2010
    C.LONDON
    4,353
    06:00 PM
    I think I've shared these before - but I'm sure Trevor won't mind me sharing them again.
    cellophane likes this.
    Moderator Drew's Avatar
    December 9, 2010
    Perth, Western Australia
    689
    01:00 AM
    Snowy,
    Can you describe how these were produced?
    Would really like to know.
    Cheers
  1. Don't Think: Improving your BIM
    By Dont Think in forum Blog Feeds
    Last Post: January 28th, 2013, 03:46 AM
  2. At least the software is improving.
    By Andrew K in forum MEP - General
    Last Post: November 28th, 2012, 07:50 PM
  3. AU Presentation
    By gdoherty0102 in forum Out There
    Last Post: November 14th, 2012, 03:18 PM
  4. Elevation Presentation...
    By t_design in forum Architecture and General Revit Questions
    Last Post: October 24th, 2012, 08:24 PM
  5. Replies: 0
    Last Post: February 27th, 2012, 06:15 PM
