Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: I Hate Interior Renderings
    Member renogreen's Avatar
    April 27, 2011
    Reno, Nv. USA
    335
    07:38 PM
    I do fine with exterior renderings and sunlight. Interior renderings are a struggle. I don't do them very often and it seems like my interior renderings always come out so dark. I'm not an electrical engineer so I'm never sure about all of the light settings.
    Anybody got any tips and pointers on how to get the lighting to show up half way accurate?
    Thanks.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    10:38 PM
    adjust the exposure & saturation. You can do some adjustment in revit or adjust it in photoshop. If that still doesn't work you can try some studio lights for ambient lighting.
    Coeur d Alene, ID
    4,783
    07:38 PM
    Also....organize your lights into groups... I usually do this by room number or by floor depending on the size of the model so I can select just the groups that I want for a view. Definitely bump up the Light Loss Factor within the family and make it brighter and I like changing the color to daylight or Xenon bulbs.
    April 27, 2011
    Reno, Nv. USA
    335
    07:38 PM
    Thanks. All of those suggestions have helped.
    March 7, 2013
    8
    06:38 PM
    Hey there,
    One little piece of advice.....Model it the way you build it, including for rendering purposes. I am a huge advocate of creating strong, powerful, creative, and dynamic views by forcing the perspective or using radical eye levels and view points. However, light is different. If you have adjusted your post rending settings correctly, and it is still too dark, you probably need to add light fixtures or if a daytime render, add more windows. Adding Studio lights is just wrong unless you argue that all of your lights are table or floor lamps and plugged into an outlet; therefore, not part of the scope of work. You don't want to advertise what is not true. It is misleading and not honest to yourself and/or your client. If it renders too dark, the space will probably be too dark. <getting off my soap box> Just my 2Cents
    Steven
    United States
    1,632
    07:38 PM
    Hi Steven, great to see you here at RFO, and I hope you'll continue sharing your knowledge and advice here!
    Generally speaking, I agree with a lot of what you've said, however... when it comes to interior renderings, the rendering settings are most often not even close to being representative of "true" lighting conditions. In many situations, interior renderings can be nearly impossible to get "right" without fudging the lighting conditions. I've seen a million excuses for Revit, but in the end, they're just excuses for a poorly implemented feature. When the developers "fix" the interior rendering feature, then we can stop using workarounds. But that's just my 2 cents as well.
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    254
    04:38 AM
    Quote Originally Posted by Steven C Shell View Post
    I absolutely agree!
    August 9, 2011
    Louisville, KY
    6,140
    10:38 PM
    Quote Originally Posted by iru69 View Post
    From my experience that is more than just a Revit issue. Granted it's been quite a while since I've done interior renderings but I have had to fake it in 3DS Max and Sketchup in the past.
    Coeur d Alene, ID
    4,783
    07:38 PM
    Would be cool if Revit had an exposure rate....like keeping the camera aperture open longer to allow for the light to fill in more....
    For example nighttime shots of houses or buildings.
    Coeur d Alene, ID
    4,783
    07:38 PM
    Nevermind....I never get into the graphic display options very much...
    Attached Thumbnails Attached Thumbnails I Hate Interior Renderings-banghead.jpg
  1. Replies: 0
    Last Post: February 21st, 2013, 01:45 AM
  2. Replies: 39
    Last Post: February 8th, 2013, 04:55 PM
  3. Latest Interior Renderings
    By cwetzel in forum Rendering and Gallery
    Last Post: April 25th, 2012, 06:04 PM
  4. Interior Renderings Kitchen and Dining Room
    By jfwithee in forum Rendering and Gallery
    Last Post: December 5th, 2011, 08:01 PM
  5. Some interior Renderings...
    By Rushdog in forum Rendering and Gallery
    Last Post: April 15th, 2011, 04:41 PM
