Results 1 to 6 of 6
Thread: Map Channels - Procedural / Texture
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    06:35 AM
    I'm trying to get a stone pattern onto my building and according to the wiki I can use a procedural map (and?)/or a texture map but I can't figure it out. I have my stone texture and can apply it but I'd like to apply a procedural map as well to cut down on the tiling effect. Can I even have multiple channels for a material or am I stuck with one or the other?
    Senior Member rkitect's Avatar
    April 21, 2011
    Oklahoma
    773
    05:35 AM
    Well, the Revit procedural abilities are pretty limited, in fact here's a list of the procedural tools they have available: Procedural Maps - WikiHelp
    You may be able to modify a checker or tile procedural to achieve what you want. I think what you may be saying about using Procedural AND texture is that you can nest a texture map into a procedural map, like this: http://gibsonhh.info:8081/revit/vide...03-15_1058.swf
    August 9, 2011
    Louisville, KY
    6,140
    06:35 AM
    hmm. looks like I was doing it backwards. I'll give it a shot shortly. Thanks.
    April 21, 2011
    Oklahoma
    773
    05:35 AM
    The thing to remember is that you can't nest a material into a procedural map. So if you want the stone material to have a good depth, you will have to photoshop that since the tile appearance options in the tile procedural map does not give you a bump map feature [that I saw, this is honestly my first attempt at this].
    August 9, 2011
    Louisville, KY
    6,140
    06:35 AM
    Quote Originally Posted by revittotd View Post
    I think you can nest it (if I'm not botching terminology or we aren't talking about the same thing). The procedural maps can also be nested into each other. Now to figure out how to get the colors correct...
    I'm excited for what this can do for grass textures! now we just need displacement mapping!
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    244
    01:35 PM
    And gamma correction, HDR maps etc.
  1. Texture sharing between users?
    By theclaus in forum Architecture and General Revit Questions
    Last Post: September 4th, 2012, 10:17 PM
  2. having a hard time joining c channels
    By nickda40 in forum Structure - General Questions
    Last Post: April 10th, 2012, 06:21 PM
  3. Where Can I get LIPPED CHANNELS family
    By Yan Naing Bo in forum Structure - Family Creation
    Last Post: October 4th, 2011, 02:35 AM
  4. Problème de texture de mur
    By Andjetya in forum Forum Français
    Last Post: June 25th, 2011, 05:36 AM
  5. question of showing texture while view 3d
    Last Post: April 27th, 2011, 09:46 PM
