Results 1 to 5 of 5
Thread: Have a problem while rendering
    February 18, 2013
    2
    10:20 PM
    Hai friends i had a problem in my project.........
    I was set the wall colour in purple, But after rendering i got the output in Megentha....
    I need your solutions pls...........
    December 21, 2010
    Phoenix, AZ
    2,556
    09:50 AM
    Most likely it's the color of your lights... if they're not white you'll get a color cast on your model.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    11:50 AM
    It could be a lot of things.
    Are you sure the material is purple? Just because the shading color (in the graphics asset of the material) is set to purple, that doesn't mean the actual material color (for rendering) is purple. I'd check that first. Make sure the appearance asset is purple.
    I'd look into lighting, also.
    GM beat me.
    February 18, 2013
    2
    10:20 PM
    Yes sir i am sure i was set the material color in purple only.......
    Pls check the image ones......Have a problem while rendering-115969_01.jpg.......Have a problem while rendering-115969_02.jpg
    dzatto's Avatar
    December 9, 2010
    5,234
    11:50 AM
    I just noticed you're using 2011. Assets didn't come out until 2013, so disregard my post. Can you post a screen shot of the rendering with the bad color in it? I think GM is correct, it's probably a lighting issue.
  1. Problem Nvidia rendering
    By honestvip in forum Hardware and Infrastructure
    Last Post: January 30th, 2013, 05:20 PM
  2. Rendering - No external lights problem
    By alligence in forum Architecture and General Revit Questions
    Last Post: July 25th, 2012, 09:31 PM
  3. Rendering Problem
    By Tom Dolle in forum Rendering and Gallery
    Last Post: May 9th, 2012, 08:33 PM
  4. Lighting problem on interior rendering
    By ncebula in forum Rendering and Gallery
    Last Post: September 26th, 2011, 12:30 PM
  5. MAJOR rendering problem
    By mdradvies in forum Rendering and Gallery
    Last Post: September 26th, 2011, 09:55 AM
