Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Like Tree1Likes
Thread: Cloud render compared to 3dsMaxDesign 2013 render (internal)
    December 13, 2010
    Ambleside, Lake District, UK
    950
    12:00 PM
    I've become quite addicted to cloud renders out of Revit 2013 but still link project files into 3dsMaxDesign2013 for wandering around the interior - it's just so much quicker and I still do quite a few still image renders in 3dsMD2013 (external renders seem better to me somehow than done in the cloud - plus I can't see a way of saving with Alpha channel included in the cloud in TIF or PNG formats ?).
    Anyway, I ran a comparison of internal renders today - one from Revit 2013 via the Autodesk cloud and one from 3dsMD2013 having linked the Revit project file (and just changed the glass material to an Arch & Design material).
    Apart from the camera being too wide-angle in the latter, the views should be much the same - but the colour balance is quite different, with the cloud rendering being much 'warmer' in tone (possibly a bit unnatural?).
    I just wondered if anyone else had come across this?
    The cloud rendered image is a bit easier on the eye - plus it took 5 minutes to render and the 3dsMD2013 one took 20 hours (iRay) on my quad-core PC with Quadro 4000 (probably wasn't using the GPU - should've knocked out rest of the model I guess ).
    Still, the cloud rendering from the Revit menu bar is pretty impressive.
    (Thumbnails attached - left is cloud rendering).
    Attached Thumbnails Attached Thumbnails Cloud render compared to 3dsMaxDesign 2013 render (internal)-2012-023_bathroom_1024.jpg   Cloud render compared to 3dsMaxDesign 2013 render (internal)-5thjanbedroomview2.jpg
    Autodesk Scott D Davis's Avatar
    March 5, 2011
    Southern California
    655
    04:00 AM
    The Rendering engines are different, which would probably cause the differences. Max will use Mental Ray, and the Cloud Rendering service is using a different rendering engine, thatI can't recall the name of right now.
    December 13, 2010
    950
    12:00 PM
    Thanks Scott - I wondered if there might be different rendering engines involved.
    I think for 5 minutes versus 20 hours I can live with the differences in most renders
    Moderator gaby424's Avatar
    December 11, 2010
    911
    01:00 PM
    the difference, is there In max is Iray if Will opted for it. Scott, I think the cloud is mentalray with settings for faster rendering times(at least the light rayes don't travel to much so they can create light reflections on objects like the Iray from the right does).
    I think that the same image rendered in 3d max with mentalray instead Iray with the same set of settings can be done on an average computer in less that 30 min. Mental ray in 3d max is extremly fast if you hunting for the quality like the cloud based render posted by Will.
    Will if you want, you can send or post that room, and I'll send back the mental ray setup so you can test how fast is on your pc mental ray
    December 13, 2010
    950
    12:00 PM
    Thanks gaby,
    Unfortunately the room is within a farmhouse and part of a complex of old buildings which is probably why it took so long to render as I had the whole Revit model in 3dsMaxDesign.
    I have read about methods of reducing the parts of the model involved in a render but never got round to doing it.
    Normally I like renders on the PC to complete in less than 30 minutes otherwise I change the settings - life is too short for long render times
    December 11, 2010
    911
    01:00 PM
    you can have a section box in revit around that room and than you export that 3d view as fbx. That`s the simplest way.
    December 13, 2010
    950
    12:00 PM
    Ah, that's it - I'd forgotten all about that - thanks again gaby
    March 5, 2011
    Southern California
    655
    04:00 AM
    Quote Originally Posted by gaby424 View Post
    It's not mental ray or iRay in the cloud. It's something more along the lines of the SilverLight engine that's available in Max.
    Junior Member theclaus's Avatar
    June 7, 2012
    34
    05:00 AM
    My experience with the cloud has been kinda wonky. Sometimes I would send the model to render and get something nice that I could continue to touch up with photoshop. Other times it would spit out something odd with textures missing or colors changed, not sure if this was something from my end or not? The cloud Rendering seems to great to "test" quickly what a final render might look like, but it was to unpredictable to me to use it for a FINAL rendering, I still prefer to do that on my own machine.
    March 5, 2011
    Southern California
    655
    04:00 AM
    Quote Originally Posted by theclaus View Post
    This is really what the cloud renderer was built to do...crank out quickly a large number of "test" renders or "design renders". It's limitations on pixel dimension don't make it great for large "presentation" type renders where you might want a poster-sized image. But what its great at is "what-if" scenarios...what does the floor look like with tile instead of wood? What do you think of paint1 vs paint2? The cloud renderer is meant to be used as a design visualization tool to help us with the design. Max is still the tool of choice for those high-end "final" presentations to the client.
  1. Cloud render res
    By assem in forum Architecture and General Revit Questions
    Last Post: July 8th, 2012, 05:24 PM
  2. Unable to render in Revit 2013
    By Andrew P in forum Rendering and Gallery
    Last Post: June 14th, 2012, 10:37 AM
  3. Render in cloud without materials?
    By dennisstevens in forum Architecture and General Revit Questions
    Last Post: June 12th, 2012, 01:21 PM
  4. Render in Cloud from Revit Server?
    By cliff collins in forum Worksharing, Revit Server & C4R
    Last Post: February 10th, 2012, 08:28 PM
  5. Cloud Render in Revit Server?
    By cliff collins in forum Rendering and Gallery
    Last Post: February 10th, 2012, 06:30 PM
