Results 1 to 2 of 2
Thread: Ray Trace vs CPU Usage?
    Coeur d Alene, ID
    4,784
    07:40 AM
    When selecting Ray Trace for a view...is it normal for the CPU Usage to max out? In shaded view and Realistic I am at 3-5%... But when I go to Ray Trace it cranks up to 100% when idle. As I move the model around it drops to 50%...but then it maxes out again and never drops.
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    770
    10:40 AM
    This is the way ray trace is supposed to work. The Raytrace mode will continue to "refine" the view while idle. That is the CPU at 100%. The view is "rendering" while the mouse is still. Then when you chang ethe view the view is degraded (CPU 50%) and then refined again once you stop.
  1. Ray Trace
    By Ian.Kidston in forum Architecture and General Revit Questions
    Last Post: March 28th, 2012, 12:04 AM
  2. Parameter Group sort order and usage
    By Gordon Price in forum Architecture - Family Creation
    Last Post: November 13th, 2011, 09:49 PM
  3. Revit 2012 RAM Usage
    By cphubb in forum Architecture and General Revit Questions
    Last Post: August 31st, 2011, 09:00 PM
  4. RST Structural Usage
    By gdoherty0102 in forum Structure - General Questions
    Last Post: May 10th, 2011, 12:42 AM
