Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By Alfredo Medina
Thread: Creating ceramic tile using a picture of the pattern
    March 12, 2011
    12
    09:17 PM
    Anyone have an idea of how I could do this?
    Orlando, FL, USA
    3,140
    05:17 PM
    1) Find an image. Save it as jpg or other common format.
    2) In Options, Rendering tab, use the "+" symbol to add the folder where you saved the image.
    3) In Materials, duplicate a material, and name it, such as "My ceramic tile".
    3) In the Rendering tab of the Materials dialog, click on the drop down arrow next to color, and select "image". Browse for your image file.
    4) In the Graphics tab of the Materials dialog, make a line based pattern, and use Texture alignment to adjust the pattern to the image.
    5) After closing the Materials dialog, edit the properties of a floor type, adding a finish layer, with your "My ceramic tile" material. Or simply paint a floor or wall with this material.
    6) Make a perspective, and make a render.
    See illustration.
    Attached Thumbnails Attached Thumbnails Creating ceramic tile using a picture of the pattern-custom-material.jpg
    cganiere and javdasht like this.
    July 30, 2017
    1
    07:17 AM
    Hi Alfedo,
    Thanks for the instruction.
    For some reason when I render the finished output does not reflect the tile image that I have used
    Attached Thumbnails Attached Thumbnails Creating ceramic tile using a picture of the pattern-colour-scheme-2a.jpg   Creating ceramic tile using a picture of the pattern-colour-scheme-2.jpg   Creating ceramic tile using a picture of the pattern-nt15-6600wp-carrara.jpg
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,453
    03:17 PM
    There are a number of reasons it might not be appearing, the top culprits are likely:
    - The material is created, but not actually applied to the element (or is applied to the wrong face)
    - Phase filters are applying a graphic override
    What element should have the material? How is the material applied (and is it applied)? What phase is the element on? What is your phase filter? What are the settings for the material?
    April 12, 2011
    Chicago, IL
    532
    04:17 PM
    Make sure the image scale is correct as well. When you're inserting the image to the material there are dimensions you can set to tell revit how big to make it. If you swap inches for feet or meters for mm, it can get pretty distorted.
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    03:17 PM
    My guess is scaling issue like Chris says.
    Hope the image helps!
    Attached Thumbnails Attached Thumbnails Creating ceramic tile using a picture of the pattern-scale-tile.jpg
  1. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 12:14 AM
  2. Surface Pattern for Topography
    By JCM in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2012, 03:10 AM
  3. Tile for Roofing
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: November 14th, 2011, 09:19 PM
  4. Changing Pattern to Region
    By pcamliti in forum Architecture and General Revit Questions
    Last Post: May 24th, 2011, 08:58 PM
  5. Creating views
    Last Post: January 18th, 2011, 03:24 PM
