Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree11Likes
Thread: Revit 2020 New Features!
    February 10, 2011
    36
    01:52 PM
    BIM Chapters: My Annual AECbytes Article - What's New in Revit 2020 http://bit.ly/2D6s1jQ Get the details here! #revit
    Junior Member scourdx's Avatar
    July 4, 2013
    44
    11:52 AM
    Cool. My office recently did travel distance and it was a lot of manual work to make it work.
    July 7, 2011
    Rotterdam, Holland
    1,252
    08:52 PM
    I use railings for that. The new feature is nice, but you have little control over what it actually does.
    As far as I can see it just takes the shortest route and you have to make sure you don't have nested generic models in your doors or they won't work.
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    656
    06:52 AM
    Quote Originally Posted by Robin Deurloo View Post
    You cant choose the path: first test I did with the advanced architectural project sample, it went through the sprinkler and electrical room!
    Mr. Revit OpEd
    2,910
    11:52 AM
    I don't recall from earlier testing, but does it make any difference if those rooms are not "Occupiable" in the room properties.
    Edit: nevermind...that's a Space property anyway...
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    774
    02:52 PM
    Quote Originally Posted by Steve_Stafford View Post
    Space and room properties are not going to have any impact on the way this tool generates a path. The tool "sees" obstacles at the category level. It does not "see" down to the properties level of things (for now).
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    245
    02:52 PM
    Maybe you could intentionally put nested generic families in doors you don't want to path thru. It's not broken it's a feature.
    December 13, 2010
    774
    02:52 PM
    ...and you have to make sure you don't have nested generic models in your doors or they won't work.
    This is not totally true. I suspect it is a case by case basis. Probably related to the specific family setup and geometry conditions. I just tried nesting a huge "disk" as a generic model on to the face of a door and the Path of Travel makes it through just fine.
    Even if I leave the visibility of the disk in plan on, it makes it through.
    Gold Coast
    2,626
    04:52 AM
    Quote Originally Posted by JeffH View Post
    good, because I use nested gm,s in my doors and windows!
    July 4, 2013
    44
    11:52 AM
    I wonder if this will impact opening family that isn't a door object.
  1. Revit 2020 Download?
    By DJC4 in forum Architecture and General Revit Questions
    Last Post: April 23rd, 2019, 03:07 AM
  2. Autodesk 2020
    By cftrevizo in forum Architecture and General Revit Questions
    Last Post: April 10th, 2019, 06:07 PM
  3. What Revit Wants: Navisworks 2015 New Features
    By luke.johnson in forum Blog Feeds
    Last Post: March 26th, 2014, 12:15 AM
  4. Revit OpEd: Schedule Features Not Available
    Last Post: October 5th, 2011, 03:00 PM
  5. Revit 2012 Worksharing Features
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 10:08 PM
