Results 1 to 8 of 8
Thread: Print to Pdf Help?
    Lurker
    September 3, 2018
    0
    04:06 PM
    Print to Pdf Help?
    Hi, I am new to this forum and was wondering if anyone can help?
    I have been trying to print drawings to PDF using Adobe PDF, all has went well with the drawings with the exception of a few where they have not printed to pdf and somehow ended up producing a text document?
    Has anyone come across this before and is there a quick fix that I may be missing?
    Many Thanks
    July 7, 2011
    Rotterdam, Holland
    1,169
    06:06 PM
    I have seen that before. Is the txt file a file with just a few lines of text?
    I think when I had that is was a problem with memory and the spooler of the PDF printer was not able to hold all the data.
    Did you try any other PDF printer yet?
    Lurker
    September 3, 2018
    0
    04:06 PM
    Hi Robin,
    Yes, the txt file is a few lines of text.
    Unfortunately the only other PDF printer installed on my system is 'Microsoft Print to PDF' but is not giving me an option for an A1 print and our systems Administrator is on leave currently.
    July 7, 2011
    Rotterdam, Holland
    1,169
    06:06 PM
    Just to check, can you turn off some stuff on the sheets that give you issues, turn off annotations for example and see if it prints OK then?
    And can you post the bit of text in that txt, it might tell you what the problem is.
    Lurker
    September 3, 2018
    0
    04:06 PM
    I have turned off annotations and still the same problem.
    The text is as follows:
    %%[ ProductName: Distiller ]%%
    Calibri not found, using Courier.
    %%[ Error: invalidfont; OffendingCommand: xshow ]%%
    Stack:
    [108 107 83 107 108 82 108 0]
    %%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
    %%[ Warning: PostScript error. No PDF file produced. ] %%
    September 2, 2018
    1
    12:06 PM
    Quote Originally Posted by Wullie View Post
    Hi Robin,
    I recommend you use PDF Creator, it’s free and it’s very simple to use
    July 7, 2011
    Rotterdam, Holland
    1,169
    06:06 PM
    Sorry for the late reply. What I can find on the web is this:
    This error can be resolved by changing one of the Adobe PDF printer settings.
    When you are in the print dialog, and you have selected the appropriate PDF printer, select "Properties."
    In the dialog box, there should be a tab titled "Adobe PDF Settings,"
    Un-check "Rely on system fonts only; do not use document fonts."
    Click OK,then quit & relaunch the application.
    June 21, 2012
    Tours, France
    937
    06:06 PM
    As Udaeta says PDF Creator is a good choice, I have it on my laptop and works like a champ!!
  1. print from dwf
    By Giladham in forum Architecture and General Revit Questions
    Last Post: November 11th, 2015, 08:26 AM
  2. Print SetUp won't show "Print to PDF"
    By NicolasMelo in forum Architecture and General Revit Questions
    Last Post: April 26th, 2015, 07:34 AM
  3. Print Visible Portion = Offsetting on the print out
    By sgray05 in forum Architecture and General Revit Questions
    Last Post: January 9th, 2015, 06:54 AM
  4. Can't print DWF (but can print anything else)
    By cellophane in forum Hardware and Infrastructure
    Last Post: July 31st, 2012, 02:10 PM
  5. Pdf print bug
    By JCM in forum Architecture and General Revit Questions
    Last Post: January 7th, 2011, 07:06 AM
