Results 1 to 5 of 5
Thread: Vertical Dimensioning in Building and Wall Sections and Elevations
    August 26, 2018
    0
    06:28 AM
    Good Morning.
    I have a simple question in regards to vertical dimensioning.
    Are you allowed to show vertical dimensions in section view?
    We see that horizontal dimensioning is possible and the vertical dimension can be indicated by spot elevations, but our office standard in CAD was to dimension some vertical elements by vertical dimension strings. Please advise.
    Thanks,
    Norbanger
    January 18, 2014
    122
    01:28 AM
    Yes, although the dimension text will remain rotated 90° (parallel to the dimension string.)
    August 26, 2018
    0
    06:28 AM
    we cant seem to get vertical dims started in section view. am I missing something simple?
    Coeur d Alene, ID
    4,801
    11:28 PM
    Quote Originally Posted by norbanger33 View Post
    If your section is not perpendicular with what you are trying to dimension to it won't work. Also if you have angled elements, such as ramps, you may have to tab until you get the dot node vs a face.
    Oh...for some the dot node is not visible...keep tabbing until it seems something is selected but it's not a face line...more than likely you got the endpoint node.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,010
    01:28 AM
    It's also possible that you have Annotation Crop turned on.
    If ANY part of your Dimension (the lines or the text) are outside the Annotation Crop, it won't display.
    It'll still be there. You just won't see it unless you turn off or stretch out the Annotation Crop boundary.
  1. Replies: 0
    Last Post: January 17th, 2017, 01:45 PM
  2. IFC, the Sections and the Elevations.
    By Gabriel Black in forum MEP - General
    Last Post: November 4th, 2014, 09:42 AM
  3. Replicating Schedules, sections and elevations
    By Jock in forum Architecture and General Revit Questions
    Last Post: November 12th, 2013, 03:16 PM
  4. moving up annotation on sections and elevations
    By frnskm in forum Architecture and General Revit Questions
    Last Post: March 1st, 2013, 01:54 PM
  5. Building and Wall Sections
    By WVReviter in forum Architecture - Family Creation
    Last Post: September 4th, 2012, 11:59 AM
