Results 1 to 3 of 3
Thread: Best software for BIM Data Storage Application
    July 30, 2018
    0
    10:45 AM
    I am looking for best BIM software that can be used to store information for operational plant or link to say a CMMS Computer Maintenance Management System. The idea is to create BIM 3D model of say piping and give attributes to welds, valves, flanges etc... I can then save maintenance information, repair work performed or unique stock code information. Can BIM be used for this? Thank you
    December 21, 2010
    C.LONDON
    4,392
    07:45 AM
    First off, Welcome to the forum!
    Now to your quiz... you're not looking in the best place.
    Thread soon to be moved.
    June 5, 2011
    85
    07:45 AM
    Quote Originally Posted by edebeer View Post
    You are looking in the wrong place. On the 3D Modelling side you would be looking for proper plant modelling software - that certainly is not Revit (caught by the marketing guff by chance?). On the Maintenance System side you would be looking for a Asset information system that links to your 3D system.
    I could name drop a few systems however you need to research your own needs and requirements.
    This will not be a small task nor will the final solution be a $10,000 install and go system.
  1. Replies: 0
    Last Post: July 27th, 2012, 09:15 PM
  2. Replies: 0
    Last Post: July 13th, 2012, 06:47 AM
  3. Replies: 0
    Last Post: July 10th, 2012, 05:45 AM
  4. Replies: 0
    Last Post: July 4th, 2012, 06:45 AM
  5. Replies: 0
    Last Post: June 24th, 2012, 04:15 AM
