Donate Now Goal amount for this year: 3000 USD, Received: 1352 USD (45%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree1Likes
Thread: Planting missing, appears as grey cubes, a known problem
    July 18, 2018
    0
    04:24 PM
    Revit provides out of the box planting, embedded in the Architectural template, planting made by a 3rd party: Archvision. Worked fine in Revit 2016, nice trees. Not so in Revit 2017, the RPC's of the third party were not loaded during Revit installation. Common problem, so I switched to Revit 2018 to see that the problem is not solved. When the work of Archvision is no longer a part of the Revit package, then why is it stil a part of the Revit Architectural template? I suspect that Archvision is no longer a part of the Revit installer. If so, Autodesk should make clear that we need to purchase the planting seperatly. I am in debate with Autodesk and Archvision about this. In the mean time I just plant other plants from other lybraries.
    Coeur d Alene, ID
    4,708
    09:24 AM
    The plantings that come with Revit should render just fine, as they do not require an archvision license.
    If they are not rendering I suspect something is wrong with your material library or you are using Revit LT which has to be rendered in the Cloud.
    Last edited by MPwuzhere; July 18th, 2018 at 08:13 PM. Reason: add Revit LT comment
    July 18, 2018
    0
    04:24 PM
    RPC's from third party, planting
    If they are not rendering I suspect something is wrong with your material library.
    First statement is true, it should be 'in the box'.
    Second statement is also true, but more refined: it is not a material. Sometimes the RPC's do not install on some computers, and I am one of them, according to Autodesk. Worked fine with Revit 2016, failed in Revit 2017 and is not resolved in Revit 2018. Maybe in Revit 2019, but I heard of other mayor problems with that, prblems with userfunctions from 3rd parties, and the out of the box planting is indeed from a third party. I am in 'full contact' with Autodesk and Archvision about this issue and a solution is not yet found. When found I will share it with all of you
    July 18, 2018
    0
    04:24 PM
    No lite versions, full versions, licenses of Revit 2016, 2017 and 2018. I know about cloud rendering, I use Autodesk A360 a lot. In the old days the software guys came with patches to fix things. Nowadays I need to surf the internet to ask the Revit community. A bit odd. It is clear that something went wrong, and I am not the only one, but neither Autodesk, nor the 3rd planting party has an answer(yet). The answer and solution will come, and I will share it with all of you.
    Coeur d Alene, ID
    4,708
    09:24 AM
    Must be missing something....works just fine for me in 2018.
    https://screencast.autodesk.com/Embe...c-77fc7e7e3929
    10,039
    11:24 AM
    Works fine in 2016, 2017, 2018, and 2019, here.
    EDIT: In case it matters:
    All Windows 10 1803 here, as well.
    Current builds on our system:
    2016 R2 SP7
    2017.2.3
    2018.2
    2019.0
    Dont have all the service packs pushed yet, obviously. But the OOTB Planting RPC's all work fine.
    By chance, did you do *install now* from the web site, instead of building a deployment?
    Coeur d Alene, ID
    4,708
    09:24 AM
    I suggest logging in with a different username on your workstation and try again...maybe something is wrong with your profile.
    July 18, 2018
    0
    04:24 PM
    Alas, no go. It makes no difference between placing a tree by topo component or by Architectural component when they are the same components. I appreciate your thinking with me, that is what we aim to do as users. I will proceed with deep contact, close encounter, with Autodesk and Archvision. F.e.: Archvision did not know that downloading their .exe files highly depends on the choice of browser. Also much O.S and iOS. No one to blaim. The cause is yet unknown. The problem accurs with some users, and I for one, want to find the cause, to help myself and other users.
    I will inform.
    July 18, 2018
    0
    04:24 PM
    My workstation is mine. No other users. I am the only administrator.
    July 18, 2018
    0
    04:24 PM
    2016 R2 SP7
    2017.2.3
    2018.2
    2019.0
    Yes, I installed 'now' from the Autodesk site, same as my Revit 2016 that worked fine. What is building a deployment?
    Could it be that I just need to reinstall Revit 2017 and 2018 in another way?
  1. Shades of Grey: PLANTING SEEDS IN DENMARK
    By Shades of Grey in forum Blog Feeds
    Last Post: October 1st, 2017, 03:45 AM
  2. roombook with rooms in cubes
    By andreasdraxl in forum Dynamo BIM
    Last Post: September 8th, 2017, 08:29 PM
  3. Keynotes Blocked by Planting
    By andrewneilson in forum Architecture and General Revit Questions
    Last Post: August 24th, 2015, 12:04 AM
  4. Problem: missing heads and tails.
    By Shinzo in forum Architecture and General Revit Questions
    Last Post: April 8th, 2013, 02:16 AM
  5. Using Sketchup imported as 3D planting representation ?!
    Last Post: June 26th, 2012, 02:56 PM
