Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By Strangeness
Thread: EIR, PxP, BEP then a spoon of MIDP with TIDP for good measure
    New Member Strangeness's Avatar
    July 11, 2018
    Hong Kong
    0
    09:11 PM
    Dear All
    Just been completing a massaive study of getting BIM off the ground and running. I wonder if anyone has written a basic list of the order of play regarding all the Forms and Schedules and checks one would have to run through before even starting a BIM Project. I was going to put together a Time Line with all the forms and then its settled. This would be a medium to large project. I guess this is not going to be an Acronym free exersize , but can anyone help break this down for me please?
    snowyweston likes this.
    December 21, 2010
    C.LONDON
    4,392
    02:11 PM
    First off, welcome to the forum Strangeness.
    Avatar says Hong Kong, but your OP's subject line suggests a UK-approach leaning? If correct, allow me to presume...
    You've powered through all the "pillars" yes? It's all fairly clear cut if you make your way through the documents one by one, page by page, and keep a running tally score (of references) as you go...
    After that, a timeline is a fine way to approach it - at first - if you've the luxury to work in linear fashion - but as the diagrams prove, nothing is linear, and you will end up leaning more toward a logic tree than a GANTT (i.e. "if yes/no go here/do this" rather than "once you've done this, do this" etc)
    That said, I recently transposed the dPOW into an .mpp (more to refresh/hone my talents with MS Project than anything else) and found it quite useful to overlay some of the core requirements (actions, deliverables, etc) from an exemplar take on "Level 2" - not that's ever our goal.
    Ultimately, the "mapping" is fairly easy. I recommend taking a big fat black redaction tool to the documents and obliterating every "note" and legalese offshoot - they condense to about a 10th their size.
    The bigger challenge, is actually creating the templates for the documents/checklists/questionaires you are actually required to make. That's the real struggle. And the real FU by those who read these "rules" - because, unlike the dPOW, they've created a whole world of bureaucracy burden, without a single proforma for anyone to use.
  1. Measure in a concrete moment during the construction.
    By manue1164e in forum Coordination Tools
    Last Post: April 5th, 2017, 03:40 PM
  2. how to measure the distance between two arches ??
    By YahyaM. in forum Architecture and General Revit Questions
    Last Post: February 21st, 2014, 01:26 AM
  3. Revit OpEd: Measure Between Two References
    Last Post: June 13th, 2012, 06:15 AM
  4. What Revit Wants: The measure of a man
    By luke.johnson in forum Blog Feeds
    Last Post: December 18th, 2011, 10:45 PM
