Donate Now Goal amount for this year: 3000 USD, Received: 1352 USD (45%)
Results 1 to 2 of 2
Thread: Importing cad files to create a revit toposurface
    Lurker
    May 18, 2018
    0
    05:05 PM
    sometimes cad drawing level lines are different just at elevation (vertical land). When I import this kind a surface to create a revit toposurface, it doesn´t consider the lines overlapping and the result is a different surface. The toposurfaces are different frrom cad and revit
    Coeur d Alene, ID
    4,708
    09:05 AM
    They draw at a different scale? I've done it for road profiles, but usually the surface is 1:1.
    I tend to request points and input those vs grabbing the SRF-LINES or Contours. Recently I had some issues as the contours followed up the side of a wall so that made things interesting.
  1. Importing and using Revit families from other files
    By kjubas in forum Architecture and General Revit Questions
    Last Post: October 14th, 2017, 07:22 PM
  2. Revit OpEd: Importing CAD Files and Invert Colors
    Last Post: February 23rd, 2015, 01:45 AM
  3. Replies: 0
    Last Post: November 20th, 2014, 07:45 AM
  4. Importing .jt files in Revit
    By sabari2504 in forum Architecture and General Revit Questions
    Last Post: January 15th, 2014, 04:04 PM
  5. Can Revit import 3D faces to create toposurface?
    By willsud in forum Architecture and General Revit Questions
    Last Post: April 12th, 2011, 06:36 PM
