Results 1 to 5 of 5
Thread: Storage Issue
    New Member whill's Avatar
    January 30, 2018
    0
    03:41 AM
    Storage Issue
    Hello guys, I have Acer Chromebook 14 which is perfect. I use it as office laptop. The overall feel and look of this laptop is very premium all specs are good, but its built-in 32gb storage is not enough for my work I want to know can I installed one more SSD in it. I don't want to use external storage. My first preferences fixed in it. So Guys is this possible or which SSD is best under $80. Sorry for my bad English.
    Thanks in Advance.
    July 7, 2011
    Rotterdam, Holland
    1,235
    05:41 AM
    You might be able to open up the chromebook and replace the SSD (and RAM) in there for a larger one. This would of course void your warranty.
    There are a few tutorials out there on how to do it (mostly for different chromebooks), for example:
    https://www.androidcentral.com/how-u...mebook#content
    Although a fun little project, be sure you know what you are doing or you might break the thing
    and of course, Welcome to the forum!
    January 30, 2018
    0
    03:41 AM
    Quote Originally Posted by Robin Deurloo View Post
    So which SSD I will install in it? any recommendation?
    July 7, 2011
    Rotterdam, Holland
    1,235
    05:41 AM
    It all depends on what type of SSD is inside of it and what kind of connection. It is probably one of the M.2 connections, but even those have different types. SO, best to open up the chromebook to have a peak inside to see what kind of SSD is in there (and if you can even replace it) and find one online or in your local computer store that will fit.
    This one MIGHT do the trick:
    https://www.amazon.com/Transcend-256...00KLTPUU0?th=1
    Coeur d Alene, ID
    4,784
    08:41 PM
    Does it have an SD Card Slot? That might be a better option instead of trying to update the hard drive. Chromebooks were created to be maintenance free, but upgrading can be a challenge.
  1. Gun Storage
    By MPwuzhere in forum Out There
    Last Post: August 31st, 2016, 01:21 PM
  2. Move Storage Location
    By buildbod in forum Worksharing, Revit Server & C4R
    Last Post: October 22nd, 2013, 09:51 PM
  3. Archiving & Storage redundancy Solutions
    By snowyweston in forum Hardware and Infrastructure
    Last Post: October 16th, 2012, 08:45 PM
  4. Extensible Storage
    By n8wex in forum Third party Add-Ins, API and R&D
    Last Post: July 17th, 2011, 11:16 AM
