Donate Now Goal amount for this year: 3000 USD, Received: 1352 USD (45%)
Results 1 to 6 of 6
Thread: Question about revit formula
    November 2, 2017
    0
    05:08 PM
    Hi everyone, i have a question please.
    I have added some parameters from 1 - 10 under data in my farmily type, which has some values. I want to write a formular at the 10th parameter to combine all the values from 1-9, as shown in the fugue. instead of typing the values again. Can someone please help me with the formular.
    Attached Thumbnails Attached Thumbnails Question about revit formula-udklip.png
    July 7, 2011
    Rotterdam, Holland
    1,172
    06:08 PM
    Pretty sure that's not possible in your family. But you can combine parameters in a schedule.
    April 12, 2011
    Chicago, IL
    523
    11:08 AM
    You're looking for concatenate, which is not possible within Revit. Dynamo can do this pretty easily, or if you have access to a spreadsheet link tool you can export it to excel to combine, and then push it back in.. As Robin said you can combine fields in a schedule to make it look like 1 field, and you can also create a multi-parameter tag that will show them all as one string. What are you trying to accomplish by making them all 1 parameter?
    December 21, 2010
    C.LONDON
    4,355
    05:08 PM
    {cough}
    Welcome to the forum Jones!
    {/cough}
    Q. May we talk about the numbers and full stops in your parameter names?
    July 7, 2011
    Rotterdam, Holland
    1,172
    06:08 PM
    {cough}
    {/cough}
    Oh sorry Jones, welcome to the forum !
    Yep, not something I would do or recommend, Pretty sure that will cause all sorts of issues when trying to use them in formula's.
    December 21, 2010
    C.LONDON
    4,355
    05:08 PM
    Quote Originally Posted by Robin Deurloo View Post
    Since they appear to be parameters for (mostly) text values, that's not so much an issue for Revit formula - but downstream they can become a real headache when wrangling datasets.
    But it's not really that, it's the notion that a value needs to be ID'd so - it's as questionable a practice as author prefixes in SP names. Width is Width.
  1. Replies: 2
    Last Post: November 18th, 2016, 02:24 PM
  2. Incremental Rounding and Unit Conversion Formula Question
    By SuperDave in forum Architecture - Family Creation
    Last Post: July 12th, 2016, 04:47 AM
  3. Question: Door Thickness - Formula?
    By AShilling in forum Architecture - Family Creation
    Last Post: July 22nd, 2015, 02:09 AM
  4. Yet another formula question!!
    By Maddren in forum Architecture - Family Creation
    Last Post: December 19th, 2012, 03:33 PM
  5. Schedule formula (is there a formula expert in the house?)
    By John McCamont in forum Architecture and General Revit Questions
    Last Post: September 9th, 2011, 09:50 PM
