Results 1 to 4 of 4
Thread: CDE product that can import & export BCF?
    Lurker
    November 14, 2014
    0
    05:06 PM
    Hi everyone,
    Is there a CDE (common data environment) product/service that can import & export BCF?
    I've tried several products such as Aconex, BIM 360 Docs, Sherlayer, Projectwise, and Viewpoint; sadly none of these products can BOTH import and export BCF(cannot stress how important this is); Aconex comes close but no cigar, does such a product/service exist?
    This is needed from a EIR (Employer's Information Requirements) under a CDE criteria list of requirements.
    I'm quite skeptical that a product/service exists out there that will facilitate this file format to this degree.
    Does anyone have knowledge of such product/service?
    Thank you!
    Coeur d Alene, ID
    4,698
    09:06 AM
    December 21, 2010
    C.LONDON
    4,353
    05:06 PM
    Welcome the forum!
    Quote Originally Posted by oneill1james View Post
    Maybe ask the author? They clearly had something in mind.
    That's "just" the plugin for other authoring/reading client/workstation tools - not the EDMS/CDE platforms mentioned.
    Member HansLammerts's Avatar
    April 22, 2011
    441
    04:06 PM
    For sharing infomation, mostly rebar, we use this webinterface occasionally
    It has some nice features as well as import / export posibilities.
    The free version has some limitations on the available GB uploadspace
    Never worked with bcf files, but it could be worth a try.
    Check the cost and overview part.
    https://www.allplan.com/products/allplan-bimplus/
  1. IFC Export/Import
    By AhmadZnait in forum MEP - General
    Last Post: May 15th, 2017, 04:29 PM
  2. Excel Export/Import
    Last Post: December 29th, 2015, 03:23 AM
  3. Import/Export autocad
    By phaeton in forum Forum Français
    Last Post: November 25th, 2013, 03:10 PM
  4. Export DWG - Import 3Dsmax
    By Severnik in forum Architecture and General Revit Questions
    Last Post: November 14th, 2011, 06:54 AM
  5. IFC import & export options
    By jhacingnanadavid in forum Architecture and General Revit Questions
    Last Post: October 28th, 2011, 07:43 PM
Tags for this Thread
