Results 1 to 2 of 2
Thread: Component or Families won't load
    August 4, 2017
    0
    12:33 PM
    Hey All,
    I hope all is going fairly well. I am working on creating a ceiling element in a new family. When I started this design I chose Generic Model ceiling based. I have my ceiling element designed but, when I try to load or insert a family or component it will not load. The item I am trying to load is a detail item, under metals, common work results for metals, metal fastenings, l-angle-bolted connection 3-elevation.
    I will go to insert, load family, and pick what object I need and still get nothing. No error or anything of that nature. I have tried this in Ref. Level and in elevations. Any help would be greatly appreciated.
    I have also tried to copy and paste into a new family and still get the same result.
    Thanks for your help in advance!
    Ed
    Coeur d Alene, ID
    4,779
    09:33 AM
    Detail items are inserted via the Annotate Tab-->Component-->Load Family
    You can select it from Annotate Tab-->Component, as detail items are 2D elements.
  1. Adaptive component warps when I load it into my Project
    By jayjayfraher in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 24th, 2017, 11:15 AM
  2. Replies: 0
    Last Post: April 7th, 2017, 01:16 AM
  3. Replies: 0
  4. Replies: 0
  5. Load generic component in adaptive model family
    By rossopiccolina in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 28th, 2016, 09:53 PM
