Results 1 to 2 of 2
Thread: Material Schedule Thickness
    April 19, 2017
    Birmingham, West Midlands
    0
    02:04 PM
    Exclamation Material Schedule Thickness
    Hi all
    I'm struggling here. I need to make a schedule for a wall with the materials separated with there thickness/width separated. I have already done a Material Takeoff but it gives me the overall thickness of the wall and not the separate thicknesses.
    For example if a wall is 260mm thick made up of 15mm Sound Block, 15mm Sound Block, 50mm Gypframe, 100mm Thermal Layer, 50mm Gypframe, 15mm Sound Block and 15mm Sound Block.
    Now when I put this into a Material Takeoff Schedule the thickness of each item is 260mm and not individualised. I have attached a screen-grab of what is coming up.
    I hope someone can help. I would be very grateful.
    Kindest regards
    Mateen S.
    Attached Thumbnails Attached Thumbnails Material Schedule Thickness-screen-grab-01.jpg
    10,278
    08:04 AM
    You put in Width, which is a parameter of the Wall. You need to put in Material: Thickness or Material: Width. I forget which it is.
    Sent from my LON-L29 using Tapatalk
  1. Replies: 2
    Last Post: February 21st, 2017, 07:20 AM
  2. Material Tag + different thickness
    By mrogucki in forum Architecture - Family Creation
    Last Post: July 28th, 2016, 03:34 PM
  3. Walls with same material and thickness display differently in 3d
    By TheCyclist in forum Architecture and General Revit Questions
    Last Post: February 14th, 2014, 01:15 PM
  4. Assembly Material Thickness reporting
    By Mel in forum Architecture and General Revit Questions
    Last Post: January 15th, 2014, 08:15 PM
  5. wall schedule core thickness
    By spotless in forum Architecture and General Revit Questions
    Last Post: July 22nd, 2012, 07:13 AM
