Results 1 to 2 of 2
Thread: Schedules, reporting parameter using IF/THEN... I think
    March 22, 2017
    Saskatoon, SK Canada
    0
    07:18 AM
    I am creating a schedule for an apartment building. I have the Suite number as the room number, the Unit Type (example 'UNIT TYPE A"), area, etc. I want to have a field in my schedule that has an integer output for # of bedrooms. I was thinking if I could use a formula that said, if Room Name= (not sure if you can use contains in this) UNIT TYPE A THEn output value is 2, if Room Name=UNIT TYPE C Then output value is 1. I took some programming a long time ago, but clearly forget most of it. Help
    Gold Coast
    2,626
    11:18 PM
    If (room=a,1,if(room=b,2,if(room=c,3,X)))
    that formula will return X if room does not equal a,b or c. Have a search for 'Revit everyday formulas'.
  1. Reporting Parameter in formulas.
    By Thasso00 in forum Architecture - Family Creation
    Last Post: July 6th, 2014, 02:39 PM
  2. Parameters reporting '0' in tags and schedules
    By joshr in forum Architecture - Family Creation
    Last Post: April 4th, 2014, 12:19 AM
  3. Reporting parameter problem
    By Tomcsie in forum Architecture - Family Creation
    Last Post: March 27th, 2014, 03:06 PM
  4. Reporting electrical system loads to space schedules
    By mog505 in forum MEP - General
    Last Post: August 8th, 2013, 10:44 PM
  5. Reporting Parameter Problem
    By tryx in forum Architecture and General Revit Questions
    Last Post: September 9th, 2011, 01:30 PM
