Results 1 to 3 of 3
Thread: Revit_Sheet configuration
    March 16, 2017
    0
    01:48 PM
    Hi all,
    Quick one:
    I am setting up a new sheet to add it on my template. Does anyone know with how can I put a text that change in just some drawings.
    For example: what I am trying to do is the Health & safety notes, and I will need some notes in a few sheets and others in the rest.
    Thank you in advance
    Junior Member RenChan's Avatar
    March 30, 2016
    25
    06:48 AM
    Are the sheets using titleblocks? If so you can put the notes there and have there visibility controlled by a yes or no parameter. Or you can just copy notes and paste to selected sheets.
    Member mjajansen's Avatar
    December 25, 2011
    The Netherlands
    197
    01:48 PM
    You can also use Legends with different text in it.
  1. Hydraulics, Flow, configuration problem
    By BasLn in forum MEP - General
    Last Post: November 27th, 2016, 05:54 PM
  2. Need help with roof configuration!
    By arhinovator in forum Architecture and General Revit Questions
    Last Post: July 21st, 2015, 12:12 PM
  3. Dual Monitor Configuration for WorkStation
    By mongoosest3 in forum Hardware and Infrastructure
    Last Post: November 20th, 2013, 11:38 PM
  4. configuration revit
    By jonado in forum Structure - General Questions
    Last Post: July 23rd, 2013, 04:35 AM
  5. Configuration autodesk revit
    By Alexo in forum Forum Français
    Last Post: February 14th, 2013, 12:23 PM
