Donate Now Goal amount for this year: 3000 USD, Received: 1352 USD (45%)
Results 1 to 2 of 2
Thread: How to change the Default Scale Value
    April 5, 2011
    14
    11:40 PM
    Is there anyway to alter the default scale value of revit?
    If you have two different scale of views loaded on same sheets it will give you a default scale value of "As indicated".
    Is there anyway to change that?
    I want to change to "As Shown" rather than As indicated..
    I dont want to use shared parameters for the scale on title block coz it taking time inputting every sheets when you can use instead the auto scale parameter from the revit itself.
    Hope to hear your ideas.
    Regards,
    kiboypalaboy
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    763
    11:40 AM
    If you are against using shared parameters for this, then you are going to have to live with "as indicated" there is no user control for this.
  1. Change Default Viewport
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: October 24th, 2018, 09:37 PM
  2. Default 3D view is wireframe - How to change default?
    By Tim West in forum Architecture and General Revit Questions
    Last Post: July 19th, 2016, 10:32 AM
  3. Default Section Scale
    By Chadwick17 in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2016, 01:26 PM
  4. Change scale from linked view ( HELP )
    By Devlin in forum Architecture and General Revit Questions
    Last Post: March 2nd, 2015, 03:31 PM
  5. Change View Scale
    By smurch in forum Architecture and General Revit Questions
    Last Post: March 26th, 2013, 06:04 AM
