Donate Now Goal amount for this year: 3000 USD, Received: 1352 USD (45%)
Results 1 to 2 of 2
Thread: Problems for rendering using lamps 2013
    January 15, 2017
    0
    07:40 AM
    Good morning:
    I´m using lamps from the following link https://seek.autodesk.com/category/L...e&locale=en-us
    but when I render the final result is incorrect.
    I can´t find my mystake can you help me?
    My Revit is 2017
    Thanks
    Attached Thumbnails Attached Thumbnails Problems for rendering using lamps 2013-01-resultado-del-render.jpg   Problems for rendering using lamps 2013-02-lamparas-descargadas.jpg
    Senior Member Alex Page's Avatar
    Wellington, New Zealand
    647
    03:40 AM
    This is an IES file problem. More about it including how to fix it are here:
    https://knowledge.autodesk.com/suppo...-rainbows.html
    (Only works if you have access to the IES file, otherwise change the IES file to something else)
  1. Rendering Problems
    By fifthtexas in forum Architecture and General Revit Questions
    Last Post: December 2nd, 2014, 10:59 AM
  2. Replies: 0
    Last Post: February 10th, 2014, 09:45 AM
  3. Rendering problems using Autodesk 360 cloud
    By Nick142 in forum Rendering and Gallery
    Last Post: April 5th, 2013, 01:25 PM
  4. Problems rendering transparent glass
    By thewrz in forum Rendering and Gallery
    Last Post: February 10th, 2012, 08:00 PM
  5. Major problems with rendering
    By Andrew P in forum Rendering and Gallery
    Last Post: May 16th, 2011, 01:54 AM
