Results 1 to 3 of 3
Thread: Convert DWG to Excel
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    12:03 PM
    Yes, I wrote that correctly. DWG TO Excel
    What I've got is an Excel file where it looks to me like the Cells are set up on a regular grid (like graph paper) and then several Cells are Merged and colored to create "Rooms"
    And they've created an entire Floor Plan using this technique.
    Apparently, this firm has a visually impaired person who can use this as an Office map, so it's not as wacky as it seems at first.
    Anyway, I'm just wondering if anyone has ever seen anything like this and if there might be a way to automate the "translation"
    Here's a clip of what they have done in the past
    Member aristide's Avatar
    July 11, 2011
    Boston, MA
    74
    12:03 PM
    Do you have Bluebeam? It's far from perfect but you can try printing to PDF and exporting to Excel from BB.
    December 21, 2010
    C.LONDON
    4,382
    06:03 PM
    Have you looked into Flux?
    Unless there's a key piece of info. (missing in your OP) as to how said person employs the Excel file it's still pretty "wacky" - in as much - if it's the coloured-plan (when printed) said person uses, then (surely) all you/they need is the .dwg produced in the same way? If the cells represent distances, a pattern/hatch grid of the same spacing could readily be introduced.
  1. Convert IFC file to RFA
    By Jack1987 in forum Architecture and General Revit Questions
    Last Post: September 13th, 2016, 09:57 AM
  2. Renaming From Excel - After Sorting Data in Excel
    By cellophane in forum Dynamo BIM
    Last Post: January 18th, 2016, 01:24 PM
  3. Replies: 3
    Last Post: June 6th, 2015, 11:18 AM
  4. Convert
    By Monikka in forum Architecture and General Revit Questions
    Last Post: December 10th, 2014, 11:01 AM
  5. Convert .rvt to .nwd?
    By Dave Jones in forum Coordination Tools
    Last Post: June 22nd, 2012, 11:41 PM
