Bifold Glazed Door
    Bifold Glazed Door
    We have a bifold glazed door which we would like to show up in our door schedule.
    Currently it is modeled as a a curtain wall, as it is likely to be made of curtain wall.
    Is there a way to get this to show up in our door schedule without modeling a custom door type?
    We don't use legend components at all for graphical schedules. We simply elevate each door and window. On smaller jobs (which we mostly do), the doors and windows are elevated directly from the floor plans. Filters can be used to hide the elevation annotations from plan view. On larger jobs we use an annotation phase to pick up the door and window types. If doing it this way then for curtain walls, group the curtain wall so that it will obviously update in both the schedule and the model.
    Michael
    Canberra, Australia
      In short? No. But you could always make a curtain wall schedule, filter it by the curtain wall type you've used to make "that" and rename the schedule... but it'd take you less than 15 minutes to make a family look just like that, so you'd be better off just setting about doing it.
        Ok, that's what I thought...shouldn't be too difficult to make. Thanks!
