Hi friends,
I came across one headache problem yesterday and still cannot seem to find an appropriate solution for this.
I have client drawings in CAD, actually this a huge 7 floor building each floor 1200 square meter of small small partition walls, apartment floor plan.
So, I open this drawing in CAD, and it looks perfect, then I import it into Revit as an underlay to start drawing the model over it - when I do import it in some proportions and rooms are double layered and mixed up lines (as if in this portion the drawing has two layers). I open the drawing in CAD again, and it looks normal, and I start digging it, exploding all the blocks and oops the same sh*t appeared. Then I checked with the supplier of the drawing and they explained that they have done some revisions to the existing plan, and they have saved it in the separate layer with visibilty turned off. Ok, I said, I went back to my Revit and started all over again, this time when importing I chose an option to import only visible layers. Didn't work out. Same sh*t. Then I thought maybe I will be able to fix the drawing in cad? I tried doing it manually, but oh my holly god, there are block inside blocks which are inside other blocks and the root block may be 5-7 blocks deeper hidden inside and all of them have 100 of layers some of them frozen some of them visible some of them off.
Close it off and relax. Now I wonder if there is any option to export a CAD drawing and have it as it looks like when you open the file, e g. without hidden layers and blocks and x-clips, yea and there are some excips that hide the existing portion of the drawings with another block. Oh my god, it so advanced that now I think I don't understand anything about AutoCAD
Anybody any idea?
Anybody any idea?
