Ok API guru's why is it some apps. end up under the Add-ins Tab and some create a new Ribbon Tab ?
With so many good add-ins popping up having them install to the Ribbon is starting to make the Ribbon long and messy.
Is there anyway us laymen can change the .addin file (or something) to determine where these apps turn up ?
Personally I would prefer them to be all located under the Add-ins Tab which leads to the next question.
Once again with so many good apps. around and having them all grouped under Add-ins Tab this Tab is starting to get a little crowded.
Is there anyway us laymen or you API guru's can create (add) a "New" Tab to the Ribbon so we have the option on where and how to organise these things.
Better still here is an opening for someone to write an app. to help do exactly this.
