I think you could open V/G in the view where you have inserted the link. From the Revit Links tab, turn off that link. Close V/G and create a view template from this view, unchecking all the other overrides, leaving only "V/G Overrides RVT links" on. Then, turn the link back on in the original view, and apply the template to other views. Since the other portions are off, this template will not override other things in the other views, just the Revit links portion.
That brings up a related questioned I've had for a while. What's the difference between opening every view and turning it off in VG, and resetting a view template to every view? I mean, I still have to open the view, go to the properties and select the template. Then go to the view tab and select "apply template to view". Unless I'm missing something. Is there a quicker way?
You don´t have to open a view to apply a view template to it. From the project browser, select multiple views > right click > apply view template > select a template > OK.
I'm sure this is default behavior, but why can't I open a linked file and the file it's linked into at the same time? I can have a cad file open at the same time when it's linked into revit. Why not let me edit the linked file, then reload it without having to close the current project?
Well damn Alf, that makes sense! Thanks for the tip. I knew there had to be a quicker way. :beer:
So let me ask you this. Other than expanding all of my categories and holding the ALT key while selecting all the views, is there a way to select all views? CTRL A doesn't work. lol
Other than this, I don´t know of other ways: Expand the views folders first, then apply a normal Microsoft Windows group selection: click the first item (view), hold the shift key, click the last item.
Oh be careful doing somthing like this. tripple check your view template and make sure you have it 110% correct. also think carefully about each view and what is in it. If you have any custom properties set the template will wipe them out.
Not if I only have a check by the link files, right? Everything else is unchecked so it won't override it.
I have set up a view template to use with some int elevations I am doing, and it does not seem to hold the settings from linked models. For example I...
Hello all! I'm wondering how I can apply a V/G override to more than one View? What I'm doing is in my Floor Plan Views, I'm going to the V/G and setting...
I am running revit 2013 and we have 5 views (overall floor plans) that has a view template applied to it. whenever anyone on the team opens the view,...
I have a revit link which I can see in red when the view hidden objects is toggled on, however when I right click the object I can not unhide it. Any...
