Does anyone know where this is? I want to add .png files
Revit 2012 Asset Library Location
Narlee,
A better approach is to put all of your files on the network, and then use AdditionalRenderAppearancePaths= in the Revit INI to point to these resources. This way everyone has access to the new files (no chance of two people rendering and getting radically different results), and a Revit Update that writes over the local folder doesn't destroy your files. And I do this even as a sole proprietor, because it makes it really easy to roll out the next version of Revit, just get the INI right and everything works.
Also, for what it is worth, i tested the hell out of the three different sizes of material texture files. Could not get Revit to show ANY performance difference. So for my own textures I do one file only, and I make the file as big as it needs to be. So a slightly textured paint might be a fairly small file, while a highly textured carpet is, well, whatever I get from the carpet manufacturers web site.Maybe 3DS max actually takes advantage of the varied files, but Revit, so far as I can tell, does not.
Gordon
I usually come across this when upgrading to a new Revit version. I find lots of backup files in my library due to modifying/improving my families, and...
Channel: Tutorials, Tips & Tricks
May 1, 2014, 12:33 AM -
Our v2017 Revit.ini files are exhibiting odd behaviour. I don't know if this has just happened or whether it has been doing it for a while - because we...February 15, 2017, 12:25 AM
I am working for 5 days on this project. Revit just suddenly clashed, and all my work has gone.
Please help, what should I do? Is there temp files...December 22, 2013, 03:55 PM -
Revitform.org member "Cellophane" dropped this reminder/tip recently....
When you save project files that DO NOT use worksets and-
Channel: Blog Feeds
June 4, 2013, 04:15 PM -
I need help with my revit deployments. I set my user files to be stored in a temp drive on our server, how do I tell Revit where to store all the temp...August 5, 2016, 06:32 PM
