Is there a way I could calculate an area in Revit by defining its boundary with lines etc.? for those who know autocad, Im referring to the area command.
Create an area plan perhaps? You can find this under plan views on the ribbon. You will need to draw the lines manually if you have no walls to associate to.
Darryl Store - Associate (BIM) [email protected]
Twitter: @darrylstore
A third option, if you are looking for finer grain information, is to create a room. (Home Tab - Area and Rooms) Once created the area is displayed in the properties of the room.
Is there a way to do a quick area calc on a plan? To draw a quick window box and have it report the area that I defined? So I don't have to create an...
Hi everyone, I am Newby with Revit. I am trying to figure out how to calculate unit floor area that will exclude area of interior walls. In the example...
I am trying to get the NIA of a building. I create an area plan and select NIA but Revit does not seem to calculate the internal walls. It only gives...
I am a new Revit user and am currently updating a model that was created by somebody else. The problem is I have redesigned the layout of internal walls...
