Is there a way to place a view on multiple sheets? For example, I have all of my interior elevations already set up on sheets, but I want to create a sketch with just the interior elevations of one room that I can print to review with my clients. Other than creating duplicate interior elevation views (not ideal), is there another way to do this?
Views on multiple sheets
Originally posted by stl4310 View PostIs there a way to place a view on multiple sheets? For example, I have all of my interior elevations already set up on sheets, but I want to create a sketch with just the interior elevations of one room that I can print to review with my clients. Other than creating duplicate interior elevation views (not ideal), is there another way to do this?Jeff Hanson
Sr. Subject Matter Expert
What do you mean by SK?
The reason this will NEVER be able to do this is if you place your section on 5 sheets which of the 5 sheets is your section head going to show? The way we used to deal with SKs is by making an SK titleblock and just placing it directly over the other sheet, print and then take off the SK titleblock.
Originally posted by Alex Cunningham View PostI would agree. Revit is able to have levels be reference or non reference. Why couldnt we have a similar feature for sections or elevations... or even drafting views.
Its the same basic idea. You dont always want a plan for every level. So you have have it not make a plan view.... ie "reference plan". Its the same basic idea...
You sometimes want to place a view on many sheets.
Add the ability to place a view on sheets without referencing. Have a master view reference requirement. Once your master view reference is placed you can now place it on any sheet, but it will always reference the master view reference.
IDk the way my brain works it seems simple enough, but i am not a programer. It would be nice to have this ability in Revit though.-Alex Cunningham
Originally posted by Alex Cunningham View PostIts the same basic idea. You dont always want a plan for every level. So you have have it not make a plan view.... ie "reference plan". Its the same basic idea...
ok, so maybe I'm misreading this discussion. But isn't this covered by the "Duplicate as a Dependent" option?Martijn de Riet
Originally posted by mdradvies View Postok, so maybe I'm misreading this discussion. But isn't this covered by the "Duplicate as a Dependent" option?
Try to duplicate with dependant on a drafting view!!! Maybe it would be nice to not have 35 duplicates of a plan... or section... or elevation, just so you can put them on other sheets.
Granted this condition dosent happen all the time and there are work arounds avaliable. But why settle for less when its able to do more.-Alex Cunningham
Is there any way to create multiple views at one time?
Our project has approximately 85 part plans, split by building and levels.
...February 16, 2012, 06:54 AM -
Stupid question:
I'm trying to place some dependent views onto sheets. I can collect the views, the sheets, the viewport location from the reference...-
Channel: Dynamo BIM
June 26, 2018, 02:02 PM -
I have a drafting view that I would like to have on a couple of sheets.
I have duplicated with detailing and placed them on the separate...December 1, 2011, 09:18 AM -
Ive created 3 dependent views off one lever ie Ventilation but for different blocks and put them on 1 sheet each.. is there anyway of copying the sheets...
Channel: MEP - General
December 18, 2013, 10:42 AM -
Hello Reviter,
I am using BIM-Link. I get some work from a college who left the office. the task:
I have a high rise bulding,...April 23, 2020, 10:17 AM
