Civil 3d to Revit
    Civil 3d to Revit
    Has anybody tried to bring TIN surfaces into Revit. Does that work better than trying to build surfaces in Revit?
    Yes the best result will come from a TIN (Triangulated Irregular Network) and a 3D contours profile which you can then use both to create the topo
    There are heaps of blogs and AU classes on this workflow
    Revit BLOGGAGE
    http://www.revic.org.au
      Originally posted by Ben-May View Post
      ...There are heaps of blogs and AU classes on this workflow
      I´d recommend having a look at the Revit Clinic, who made this great post on the topic.
