can we change design option to another option ??
    Hi, I have design and there is options inside it now i want to make some of it into main model so it can be editable within main model say i will move option 2 into main model so i can edit it in the main model because wall of option 2 is not joining with main model and i want also to move some options like option 4 to option 3
    is this possible and i do not know !
    Select the objects to put in main model, then use Cut (Ctrl-X) and Paste them into the Main Model.
    Scott D Davis
    Sr. AEC Technical Specialist
    Autodesk, Inc.
    http://bit.ly/aboutsdd
      I thought there is a button that assign them to specific option but anyway Good trick :thumbsup: so if i have objects in option 3 that i want to put it in option 2 just CTRL-X to option 2
        You can also use the Add to Option set button in your status bar. It doesn't always work though - if it doesn't, copy / paste will work.
        chad
