i tried searching the site but no joy...i may be asking the impossible here...are you able to change the elevation level that a floor plan view is associated to?
level association
Not quite sure what you are trying to acheive or what you want to move or associate to another level, but maybe have a look at this little app. it will select and show you eveything that is associated with a selected level.
Could be a good place to start, when you really need this app. its worth its weigh, and some.Mark Balsom
Originally posted by elton williams View Posti tried searching the site but no joy...i may be asking the impossible here...are you able to change the elevation level that a floor plan view is associated to?
Hi guys,
Is this possible to take all model information form one building level and swap it with another level in the same building model? I mean...June 29, 2016, 09:47 PM -
Can someone help about how to set up Levels in Zero in a multi storey floor project. for Example, A project with Basement Level, Ground Floor Level, First...March 26, 2019, 10:28 AM
one of the levels I created in section does not show up as a floor plan. what gives?May 18, 2012, 02:46 PM
Friday afternoon in stifling heat, so the answer to my following question may really be that the brain just needs to go home ......January 20, 2012, 12:30 PM -
I am creating a ductwork model and I am working on level 2.
There is no floor separting level 1 and level 2 so I can now see the ductwork...March 21, 2013, 04:51 PM
