I am working on floor finish plans and the door I am using does not mask the floor tile pattern below. I have not located a setting in visibility and graphics to handle this and wanted to know if this needs to be part of the door family. Thanks for any advice on how this should be handeled. I have attached a screen shot to illustrate the issue.
Door does not mask floor patern below
While you're at it, you may as well create a door swing locked to a reference line so you can control the angle. All Revit doors are set to 90 degrees, while I prefer to show them at 45 degrees. With an adjustable door swing made of linework and a masking region (if you want it) nested into the door leaf family, you can make the angle anything you want.Dan
Thanks for the advice. I have tried to edit and modify the door family with only marginal sucess. The door already has parameters to adjust the door swing in plan view. When I apply the masking region to the door, I am only able to lock it to a couple of the faces. The other elements whicha re part of the door swing do not allow me to lock the masking region to it. I get the attached error. I sort of works when the door is opened to 90 degrees, but stays at 90 when I change the door swing. I have just dabled with families and clearly I need to spend more time learning this animal. Any resources that you can direct me to in order to help with families would be appreciated. Thanks again for all your help.Attached Files
Originally posted by dzatto View Postcould be anything. Can you post the door family? We may be able to figure it out, then let you know.Attached Files
If you're using a filled region, the align/lock to the reference line (that's controlled by the angle parameter adjusting your door swing) also needs to be dimension locked to the parallel face of the panel, and the ends of the panel will also need to be locked with a 90-degree angular dimension (at both ends of the sketched line) to both of these. If you do this all in the sketch, it keeps the view of your family a little cleaner... but...
As you can imagine, that's a lots of locks to keep on top of. You'd do well to look at using a detail component for this kind of thing - that way you have control over that element "there" and simply place it as required, in the door family.
Originally posted by snowyweston View PostIf you're using a filled region, the align/lock to the reference line (that's contro11ed by the angle parameter adjusting your door swing) also needs to be dimension locked to the parallel face of the panel, and the ends of the panel will also need to be locked with a 90-degree angular dimension (at both ends of the sketched line) to both of these. If you do this all in the sketch, it keeps the view of your family a little cleaner... but...
Thanks for the suggestions. I have played with this with marginal success. First I tried applying the masking region to the door swing and locked to faces to the two swing reference planes using align. I am not sure what the dimension lock to the parallel face meant exactly, but I dimensioned the masking area and references the parallel faces to the door width and the door thickness. I then applied the 90 degrees angle locks on two corners. I loaded this into the project and it would still not rotate. I tried this both when the door was open to 90 degrees and 0 degrees. Subsequently I discovered that the door swing itself was a referenced in family and tried the similar procedure in the door swing library - I thought this would do it, but when applying the masking region here appeared to have no effect when the finished library was loaded into the project - no masking at all. I am attaching a screen shot of the door swing family and am attaching the family itself.
Be aware that masking regions are on the Category and not a Sub Category. This means you cannot selectively display it off while leaving other door components on. I made a beautiful door with a masking region to obscure the floor tiles, however the masking region turns up in my ceiling plans obscuring my ceiling tile pattern.
My ceiling plans show the door opening and frame only, not the door or swing. So now I just live with simple line work for my door panel in plan.
Hello people,
When I place a standard door (a pre-defined door) in floorplan 0 the door, including the direction of the door, is visible....March 24, 2014, 08:00 PM -
I have a 1219 w door that has also included the family a door frame (51 each side the door. The way this is currently drawn, it also has an allowance...August 20, 2020, 01:39 AM
Hi Guys
I am thinking how to make a custom made door family in revit.
This one is what i have to load into a project. In the middle part there...October 31, 2017, 01:32 PM -
I have a window that I have made, that has a nested door within it. The screen is 6500mm high, so spans over 2 floors. I cant get the geometry to display...
April 23, 2013, 12:41 PM -
Ill try to explain this as best as I can. Does anyone know if there is a way to get door swings to appear at a 45 degree angle when they are inserted...
September 14, 2015, 08:22 PM -
