Is there such a thing?
In the past i have been using reference lines setup at 800mm centres for my distance between dimensions, however a conversation with one of my drafties they suggest its possible to have this to auto snap 800mm off the dimension closest to it.
i have had a look and cant seem to find anything regarding the dimension family?
is this possible? it would certainly be handy if such a beast does exist.
Im aware of the Dimension Line Snap Distance (set at 800mm) but that doesnt do anything!
As is per usual with Revit, its usually the simplest thing possible, but its escaping me at the moment what the solution is.
