Doors to/from room field not populating
    One of our clients has come back to us saying that her doors are not populating the to/from room fields in their door schedule. I've gone back to her asking for more information (I cant replicate the problem), but has anyone come across this before?
    Alex Page
    RevitWorks Ltd
    I've been looking around and found some interesting points:
    1. The Rooms Instance Properties Limit offset has to be at least 1/2 way up the door. For example, if you have a 2m door and the rooms Limit Offset is less than 1m it will not show up in the schedule.
    2. The room needs to be deeper than 320mm (!) - so shallow cupboards will not work.
    Any others?
    Alex Page
    RevitWorks Ltd
