Folks,
I am using Curtain System by Face to make curtain wall on sloped walls. What I am having a problem with is the default orientation of the mullions. Some of my faces have oddly angled tops and bottoms and the vertical mullions seem to be looking at those edges to get something to be perpendicular to...at least in the first application. If i adjust the vertical mullion angle to be vertical, then 'Update Face' it is off to the races mullion-angle-wise. Not only does it change from what I set it to previously, but it isn't perpendicular to anything. Rinse and Repeat if desired.
This can't be the only song this tool can sing and I bet I am missing something. Is there a way to hardwire the mullion angle so I can set it and forget it....is there a way to make it always align to a level or soemthing? Any help would be great.
Thanks,
Drew
Thanks,
Drew
