I'll start this one off with a great blog from dODDS and ENDS.
http://doddsandends.typepad.com/blog/qto/
Also, if using the 2010 release with Windows 7 here is a workaround to get it to operate.
With the recent release of Windows 7 we are starting to see which software is compatible with the new operating system. With QTO being created before Windows 7 it is not supported by Autodesk and does not function without a work around. When you start QTO everything appears to work fine until you go to open, or create a new project. You will receive an error that says “Could not load file or assembly ‘ADOX, Version=2.8.0.0, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. The system cannot find the file specified”. Once you press OK the software will either crash or your workspace will be blank. The reason behind this is the ADOX file is needed to run a VBA application for Vista and XP, but one does not exist yet for Windows 7 in the installer for QTO. So we can use the one for Vista by:
1. Make Sure QTO is closed
2. Insert the installation disk and go to the path: \x86\Autodesk\QTO\Vista\ADOX.DLL
3. Copy the ADOX.DLL file to the installed QTO use directory: C:\Program Files (x86)\Autodesk\Autodesk Quantity Takeoff 2010 (you will need ADMIN rights for this)
4. Restart QTO and open any ATO file or create a new file. The program will have full functionality.
This should be fixed by the 2011 release but for now this is the only way to get it to work.
I will continue to update this with more information as I come up with more solutions to issues that I run into.
Also, if you're feeling bored, you can read my quick primer to using QTO 2010 found on AECBytes.
http://aecbytes.com/tipsandtricks/20...todeskQTO.html
