Revision Cloud Description Issue
    In my company, we describe every revision stage from A to ... something.
    I found that in revit , there's some label description only for CURRENT REVISION.
    Any solution?
    thanks.
    By the looks of it you’re after a revision schedule on you sheet? In you title block family add a revision schedule (under the view tab) You’ll be able to list as many previous revision as you can fit on your sheet. Just make the schedule as long as you need.
    HTH
      WOw! That's what I wanna know.
      Thanks guy.
