How to set dmension for parts to Foot- inch fraction
    Novice
    I don't know how to get my drawing sheets to have part dimension in "imperial" (actually USA)
    feet and inch format. The dimensions are in inches. I have Style set to Architectual Project Preferences with tolerance of 0'-0 1/16". I have set Dimension Style to the same. The first part drawing that I specified shows all dimension in inches only.
    Will someone send a reply that will give me some way to correct this problem: show drawing dimensions in feet-inch instead of only inch?
    Thanks for your help!
    billbe
    Check out image attached, should help you out. Also make sure to check out step 5 for "rounding".
    Hope this helps you out, got to feel sorry for you, "Imperial" seems so backward !!!!
    Mark Balsom
      Mark, Thanks for your reply,
      I didn't mention in my first post that I'm working in AutoCad 2011 Structural Detailing. The thumbnail you sent doesn't look like my SD screen. Is it possioble that your are in Rivet Structural?
      As far as my problem with feet inches, I am going to try to make changes to AutoCad 2011 Deminision Style before opening Structural Detailing. Maybe that will work to get feet-inch deminisions on detail drawings.
      billbe
        oh man, are you in trouble. I'd be :hide: if I were you :crazy:
          You are working in what ?? Autocad ?? Now I really can't help you, sorry.
          Mark Balsom
            Hi Billbe,
            I noticed that all your posts pertain to ASD. Even though there's a subsection here for ASD, most of this forum is really dedicated to Revit. Not that Revit users wouldn't want to help, but there probably aren't a ton of users here who are familiar with ASD. You might find more info and responses to your questions at AUGI, where they have a dedicated forum for ASD... and certainly more info for AutoCAD in general. But you're certainly welcome here... maybe it's time for you to switch to Revit Structure?
            :beer:
              ... I'm working in AutoCad 2011 Structural Detailing.
              billbe
              As Iru69 said, this forum is mostly for Revit issues.
              I don't have ASD, but I do have AutoCAD on my computer. Dimensions in AutoCAD can be very challenging; at my old firm I had a "cheat sheet" created to give to my team members for when they had issues with dimensions.
              Since I don't have ASD, I don't know if there is a difference in dimension setup from AutoCAD. But I can help you a bit with AutoCAD.
              Type in "dimstyle"
              You should get a dialog box that has listed the different dimstyles that are already in your dwg file.
              You either have a standard one your firm uses, or you're going to modify one that's in there already, or you're going to make a new one. If the firm already has standard ones that are already set up correctly, I typically don't mess with those, but I might start with one to make my new one.
              On the left, I highlight the one I'm going to start with. On the right I click <New...>
              You have a chance to give your new dimension style a name. You also have a chance to base it on a dimstyle that's already present in your dwg file. <Continue>
              In order to set your dimstyle to be in feet and inches, look at the "Primary Units" Tab. Under "Linear dimensions" look at the "Unit format:" input. Make sure this is set to Architectural.
              There are so many more adjustments to make to your dimensions but, not knowing what your firm's "standard" is, I'm going to stop here. If you need more help getting the dimensions to look the way you want, maybe post back, possibly with a picture of what your dimensions *should* look like.
              Leanne Zaras, CDT, LEED AP
                Hi iru69.
                Thanks for your reply. I have three comments.
                I am a retired former P.E. Structural Engineer. It's hard to teach a old engineer new tricks. Learning difficult software is a way to S t r e t c h my stiff brain.
                I don't want to work in a consulting firm making structural design drawings. I want to work as a contract detailer for structural fab shops on a "per detailing job" basis.
                I have Autodesk Revit Structural software. After I learn to use ASD (if I do) then I'll take up Rivet Structural.
                I have found that AUGI don't seem to know that much as this Revit forum has many more members who try to help.
                I don't know why AUGI doesn't answer my questions even though a few look at them. Do they don't know much or they don't want others to learn the software and be competition for work? In this country there is probably more detailers than there are projects to detail.
                I think and hope that some members on this forum knows enough to answer my questions!
                  Novice
                  billbe
                  I don't have ASD either but still use Acad quite a bit. Try Leeann's suggestion and see if you can get a dialog box when using the DIMSTYLE command. In regular Acad the setting for inches only is Fractional and for Imperial ft/inches it is Architectural. Somewhere you must have those options.
                    Billbe, I don't have ASD either, so I'm not exactly sure what I'm talking about here :hide:, but (based on Acad 2010) in addition to 'dimstyle' command try 'units'. Hope this helps :beer:
