Phases
Thats exactly what it was doing to me too...was always setting the cut view to "Show All"...glad I'm not alone!
Oh, OK... Sorry.
Let's see...
Plan in Phase: New Construction, Phase Filter: None >> Section is Phase: New Construction, Phase Filter: Show All.
Plan in Phase: New Construction, Phase Filter: Show Previous + New >> Section is Phase: New Construction, Phase Filter: Show All.
Welp, I guess the sections don't hold the Phase Filter in RST. Hmmm.
Leanne, you told us about the Phase for both of those, and the phase will always take from what it is being cut in...what I am having issues with is it taking the Phase Filter with as well....can you take a look at how it treats your Phase Filters when you cut?
UPH! Not so fast. I'm using RST2011 and just tested.
When plan is in Phase: Existing, I cut a section. That section is in Phase: Existing.
When plan is in Phase: New Construction, I cut another section. That second sections shows Phase: New Construction.
something must be up with gdoherty's RST. <shrug>
Perhaps...it still is not working for me...not a big thing, view templates work well...
Does this mean RA finally has a cool feature RST doesn't have??? WOOHOO!!!
using RA 2011. and it's a true section. but I'm pretty sure it does it for any view created from another view, callouts, sections, elevations...
Originally posted by CBukowski View Posttakes both here. I just tested it. I can cut a section with my New Construction phase filter on, it shows the section with New Construction Phase filter in the same phase I'm working in. Then I change the phase filter to Existing in the plan and cut a new section, it has a phase filter of Existing...
I have a multi-phase project for which I need to create a view that shows all of the demolition work across all phases. Initially it seemed that setting...January 4, 2011, 11:16 PM
I've read a little on phasing, and I don't think this is easily doable, but I'll ask anyway. I need to show Phase II of a house design halftone. Is...June 5, 2017, 06:36 PM
Is there any benefit to setting the phase filter to 'New' on views that do not show existing elements? Currently our phase filter is set to 'Complete'...May 3, 2016, 04:38 PM
Hello!
I noticed we had a problem with phase filters and was able to narrow it down to this:
The Setup:
I...March 28, 2012, 09:12 PM -
I note this closed thread: https://revitforum.org/showthread.ph...ing-Next-Phase
Can I revive it please? The following...December 11, 2020, 06:10 AM
