Formula Help - If statements
    I'm trying to put together a formula to calculate total exit width and have it almost there. The problem pops up when one or more of my fields does not have a value. With no value I get no result. I'm 99% sure an IF statement would fix it but I'm not sure on the implementation. I've looked at the forumla thread but algebra was never my strong suit...
    Formula: width1 + width2 = exit width
    if W1 and W2 have values it works fine: 1+1=2
    if W1 has a value, and W2 does not - I get nothing: 1+ =
    chad
    In Revit you take a null value and do anything to it through a formula you get a null value in return. You will have to set your null to 0 to make it work.
      Gotcha. Is it possible to ignore the null if it exists?
      chad
        Not that I have ever figured out.
          edit:
          Would it be easier to let the schedule total the value using the checkbox to "calculate totals" on the formatting tab?
          http://www.captiveaire.com/
          Commercial Kitchen Ventilation Systems
            I did but with multiple parameters I just wanted one value. I ended up just creating a parameter for my doors that added everything up in the family and scheduled the new parameter.
            chad
              try this (out of the top of my head):
              if(width1 >0,width1,0)+if(width2>0,width2,0)
              not sure if it will bite.
              You can do it for sure using calculated formulas but I'd have to check the syntax. I believe Gordon wrote a PotM nominee about it and I'm sure I used this trick in a blog post here once.
