Interior Elevation
    Interior Elevation
    Dear all,
    When I tried to create an Interior elevation in a project which I got as a basic sample training file with RAC 2011.. ( I could not attach it here due upload limit) Revit is giving a warning...stating that “None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings”.
    I tried in view range and changed primary range and cut plane value to some different values..but still I could not create it only building elevation is available in the "Type Selector"..what should I do..??
    Anybody can give some direction in this regard...?
    Advanced thanks..!!!
    The elevations will have been created (check your project browser) but for them to show in your plan viws, you will need to make sure they are turned on, in visibility and graphics, under annotation.
      Thanks Mr.Weston.....I checked the the elevation box from visibility/graphics option..then the building elevation is appearing in the plan view and I could create the elevation. But unfortunately only building elevation is available in the type selector..what should I do to get the interior elevation in the type selector box..?!!
        You will need to define one, OOTB the Revit template calls the section type "Building" but it essentially is any elevation - but if you want to differentiate elevations (by application, with different elevation head markers, sort by "family & type" in your browser, etc) then you need to select an elevation placed, go to it's type properties, then duplicate, rename (and configure) as desired, and then you will see you have different types to choose from.....
          Yes Man...you are correct....now I am on the track...cheers...:beer:
            If you haven't read through them, I have a list of good intro posts compiled:
            http://www.revitforum.org/architectu...point-rfo.html
            The template post and can't see it in a view are both really good (imo).
            chad
              Thanks for the Reference cello...!!!
