Hello, I am doing some massing, and i was wondering how do you create a chamfer box, like one in the picture:
How to create a chamfer box
In Revit there is no fillet tool for solids, like there is in other programs. One possible solution is this: use a void with filleted interior corners, to cut the solid cube in 3 different directions, one at a time. See illustration.Attached FilesFreelance BIM Provider at Autodesk Services Marketplace | Linkedin
Yes, it would be like two separate rectangles but they have to be part of the same sketch for the extrusion. The reason is that the the double lines create a sort of shell, with the interior part having no geometry and the offset of the rectangles give the void a "thickness" (anything that intersects this thickness will be subtracted from the box)
That's what I was thinking, but it seams I can't get to cut the box... I get this error message when I select two rectangles, and click voidAttached FilesLast edited by Munkholm; February 28, 2011, 09:51 AM. Reason: Changed IMG to attachment with thumbnail.
It can also be achieved with one chamfered extrusion and one "chamfer sweep" that cuts both top and bottom of the box.
This, and all previous suggestions, will only get you chamfered edges though... To also chamfer the corners (as the linked example in the OP), you´ll need to create the corners by 90 degree revolves... Like in these attachments :beer:
Edit: In the attached example, I made the corners in a different material to make them stand out - instead, use "Join Geometry" to make the box appear as one solidKlaus Munkholm
Morning all,
I'm producing a family of commissioning modules for fan coil units. Each has a certain number of ports, which are, in reality,...-
Channel: MEP - Family Creation
March 13, 2014, 11:27 AM -
Please see image.
How do i achieve my hand drawn sketch please?
Cheers Andy...-
September 7, 2016, 03:21 PM -
Hey building a crown molding for a kitchen and it needs to be a U shape and parametric ( i tried using a sweep first and it worked fine, but the problem...
January 16, 2014, 06:40 PM -
Void extrusions in a family. Revit 2015. Why does it turn orange and not cut the geometry??? When I try to cut it manually, it tells me "cannot keep...
May 16, 2017, 02:55 PM -
Hi!
I am here trying to make Voids work, but something is not right! I'm EXTREMELY confused, so I captured lots of screens to make myself...June 26, 2011, 11:37 PM
