is there any way to get a Tekla model into Revit other than IFC?
Tekla to Revit?
Hi Dave,
I think that with another format than IFC, you will loose the BIM side....
I've heard about Revit addin for Tekla a time ago. You should check.Julien
P. DAC
I've heard about Revit addin for Tekla a time ago. You should check.I'm retired, if you don't like it, go around!
Be aware that Tekla BIMSight DOESN'T export a model to Revit. It's similar to Navisworks Review or Solibri Checker. You can import ifc components and compare them. But no exporting Tekla directly to revit. You have to do this through IFC.
The good news is though Autodesk and Tekla did announce they want to make this work better.Martijn de Riet
Originally posted by mdradvies View PostThe good news is though Autodesk and Tekla did announce they want to make this work better.I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View Postnot good news for me who has to have a project done in 6 weeks and the structural model is done in Tekla. I guess I'll try an IFC file
I'm assuming you already found this plugin: http://www.tekla.com/international/s...tructures.aspxMartijn de Riet
Originally posted by mdradvies View PostDid I say better? I meant "even better than it already is".
I'm assuming you already found this plugin: http://www.tekla.com/international/s...tructures.aspxI'm retired, if you don't like it, go around!
Originally posted by Dave Jones View PostI had not seen that so thanks for the link Martijn! I'll see if I can get the Tekla user to use this Export to Revit ap
But, how am I to complain when I get the rep for it...Martijn de Riet
Hello, does anyone have experience with working with tekla ifc models in revit? When I open the model in revit some of the walls are misplaced, but when...
Channel: Coordination Tools
July 18, 2011, 07:18 PM -
I have been using Revit for a while and have now got myself Revit 2017 installed.
I am by no way "good" at using Revit, I am purely self-taught...June 28, 2016, 01:50 PM -
Hello everyone I need some help:
I am working with a consultant who has asked for an IFC4 export from outlr revit model.
They rely...-
December 13, 2019, 04:44 PM -
Hi All,
Could anyone please export an IFC file to Tekla Structural Designer file? I exported it from Scia Engineer and I would like to use...-
February 19, 2019, 02:18 PM -
Link IFC in Revit 2015 differs from Opening an IFC file in Revit 2015?How can Revit IFC files being (not) or different processed through the "Link...October 22, 2014, 12:14 PM
