How should Fill Patterns, Line Styles, Line Patterns, etc. be named ?
Naming Convention - Other
This topic is closed.
This is a sticky topic.
This is a good question. I would love to hear what people are doing. For example: Spaces or no spaces within the project enviroment? for eg. Some of the OOTB linestyles have spaces in their names.
If not, why?
I have seen it said that it is not recommended within families to use spaces, therefore I would expect that to carry right across all things Revit.
ps. I love this sub-forum, so much useful info...Last edited by Darryl_S; March 8, 2011, 09:29 AM.
<Identifier>_<Category>_<Type>_<Descriptor>_
<Identifier>
#RFO (The "#" to sort on top)
<Category>
Short abbreviation of the category name:
Fill Pattern = FP
Line Style = LS
Line Pattern = LP
etc
<Type>
For Fill Patterns only.
Model Pattern = M
Drafting Pattern = D
<Descriptor>
Pattern/Line Style name
Now, for me I normally also add the SfB-code in the Fill Pattern name (MasterFormat code). This way I have a more detailled list of Fill Patterns so I can assign different Fill Patterns to different Materials. This way I can edit the fill pattern for a specific material without having to worry about changing other materials by accident.Martijn de Riet
Our naming conventions basically follow everything else weve done, but here is a major sticking point for me. Since i dont want to retype it, a copy of an email i sent recently:
Just a quick thought on Materials, Fill Patterns, and the Family Editor:
My last office in New York adhered fairly strictly to the National CAD Standard, which- as I'm sure you know- is very particular about hatch patterns and line types. Revit handles all of this beautifully (kudos to you). Except: I ended up writing all of the pat files in a new .pat file, and they were named by FUNCTION, not by graphic. Worth mentioning, the office remained 50% ACA and 50% Revit, and we did this new system for both halves, and it was unanimously well received. Line patterns weren't "Dashed" they were "Demolished Items." There wasn't a "Hidden Line" type, there was a "Roof Overhang" linetype.
The same was true for Fill patterns. It wasn't "Diagonal up 1/16"" it was "Brick-Cut." It wasn't "Crosshatch" it was "CMU-cut." Sometimes, yes, that meant two patterns with different names were actually the same pattern definition, but that's a GOOD THING. Things were broken up systemically. It also prevents inconsistencies... "Which cut pattern is CMU block again? Crosshatch or Crosshatch-small?..." So, ive done the same thing in Revit for our materials, fill patterns, and linetypes...
The moment i see the generic Fill patterns, Line Styles, Linetypes, whatever... They get deleted from the content, setting them all back to default.
I also like function (the purpose) involved with naming. A text style name like "Arial 3/32 underline and bold" is descriptive but it doesn't tell me whether I should use it or not. Text style names like Notes Headers, Notes Regular or Notes Emphatic start to suggest their purpose like styles in word processing software.
The more obvious it is to someone trying to choose something to use the better the system works. Personally, visiting different firms can be awkward for me to get acclimated. I don't see this strategy in place very often but it sure helps me get my bearing. Think like a user, there are 15 text styles listed, which one am I supposed to use?
Yep, me too. My <Descriptor> is always a functional one. I hate it when I get a model with patterns that are named "Diagonal Up". Not only I cannot tell what it's for, I can also not tell where it has been used before. So I end up duplicating it before modifying just to be sure I'm not screwing something else up. Which off course gives me a lot of redundant types...Martijn de Riet
Ladies & Gentlemen,
I’m trying to come up with a naming scheme for fill patterns and was hoping for some advice. This seems to be...January 30, 2017, 09:15 PM -
I suspect the answer to my question is, "that's impossible" but hoping someone will have a creative solution for me.
I'm trying...November 23, 2017, 12:13 AM -
Is there a way to override a model fill pattern to an element instead of drafting pattern? I am trying to assign a tiles pattern to a wall elevation but...September 30, 2017, 07:09 PM
Hey guys, I'm new to this forum.
I just got the Revit 2014 and been having problems with hatching/patterns. I think my main issues for now...June 2, 2013, 09:15 PM -
I responded to a thread at Linked In this morning, something I almost never do. I find LI too frustrating to spend much time there. Regardless, the sought...
Channel: Blog Feeds
September 13, 2016, 05:15 PM -
