Here´s a good reason to store rebar nets inside - Pretty sure that it won´t reinforce anything but the ice in the current state :laugh:
Store rebar nets inside
COOL! :laugh:Martijn de Riet
Originally posted by Munkholm View PostHere´s a good reason to store rebar nets inside - Pretty sure that it won´t reinforce anything but the ice in the current state :laugh:
Originally posted by gdoherty0102 View PostI wonder if they have thought of doing things like this on pourpose...there are massive ammouts of heat released from concrete when it is poured...be interested to see if this type of set-up would do anything with that heat from the inside...especially on larger pours such as dams.I'm retired, if you don't like it, go around!
Yep, I just read that they figured if they just poured the damn as one huge pour, it would take 125 years to cure. lol
So what did they do? They did it in squares. Inside of each of these "squares" they put metal piping that would allow river water, then refrigerated water to run through the center of the pour and disperse the heat. When they were done, the filled the pipes with grout.
Pretty slick, considering it was done in the 1930's. lolDan
Originally posted by Munkholm View PostIt´s a chemical reactionI'm retired, if you don't like it, go around!
Originally posted by gdoherty0102 View PostNow...I may be a little off on this, but I don't beleive so. Chemicial reactions cause a change in energy, this energy is usually dissipated as heat.
A large floor slab has a large area to dissipate the heat across, so could be un-noticable in one area.I'm retired, if you don't like it, go around!
I am new to Revit and have alot of questions. First one being, while using Revit Structural I noticed that the software has the ability to automatically...
Channel: Structure - Family Creation
March 12, 2011, 05:52 PM -
How to create a rebar family in revit structure
October 8, 2014, 12:38 PM -
I modeled floor slabs, from there I went to section views and placed Rebar in them. I had to make some changes and add more Rebar after that. I see that...
January 19, 2012, 05:46 PM -
I was tinkering around with the rebar placement and got it working (woo!) but the rebar shows up in all my sections, even when it should be covered by...November 26, 2013, 08:57 PM
Hi!
I have a question about reabars, in RST 2013, when chancing the hook my rebar chance type.
I mean A rebar shape "A"...-
May 12, 2013, 11:09 AM -
